No subject
houston at mgm.lan.mcgill.ca
Fri Jun 4 02:18:00 EDT 1993
(5.65a/IDA-1.4.2b/CC-Guru-2b)
id AA03364 (mail destined for houston at mgm.lan.mcgill.ca) on Thu, 3 Jun
93 15:23:57 -0400
Received: from amber.cecer.army.mil by max.cecer.army.mil with SMTP id AA14695
(5.67a/IDA-1.5 for <houston at mgm.lan.mcgill.ca>); Thu, 3 Jun 1993 14:20:14
-0500
Received: from zorro.cecer.army.mil by amber.cecer.army.mil (4.1/SMI-4.1)
id AA11681; Thu, 3 Jun 93 14:10:51 CDT
Received: from amber.cecer.army.mil by zorro.cecer.army.mil with SMTP id AA00825
(5.67a/IDA-1.4.4 for <grassu-people at amber>); Thu, 3 Jun 1993 14:10:49 -0500
Received: from max.cecer.army.mil by amber.cecer.army.mil (4.1/SMI-4.1)
id AA11671; Thu, 3 Jun 93 14:10:46 CDT
Received: from boulder.Colorado.EDU by max.cecer.army.mil with SMTP id AA14497
(5.67a/IDA-1.5 for <grassu-list at max.cecer.army.mil>); Thu, 3 Jun 1993 14:10:46
-0500
Received: from noaacrd.colorado.edu (noaacrd-gw.Colorado.EDU) by
boulder.Colorado.EDU with SMTP id AA21343
(5.65c/IDA-1.4.4 for <grassu-list at moon.cecer.army.mil>); Thu, 3 Jun 1993
13:10:45 -0600
Received: by noaacrd.colorado.edu (cu.generic.890828)
Date: Thu, 3 Jun 93 13:10:50 MDT
Message-Id: <9306031910.AA29649 at noaacrd.colorado.edu>
Sender: lists-owner at max.cecer.army.mil
Reply-To: grassu-list at max.cecer.army.mil
Precedence: Bulk
Sender: lists-owner at moon.cecer.army.mil.
Reply-To: grassu-list at moon.cecer.army.mil.
Precedence: Bulk
Subject: Dumb Terminals and SUN's
Craig:
>Has anyone successfully tied a dumb terminal (VT100) into a SUN in a
>manner similiar to many Image Processing Packages? This would provide
>a vt100 terminal for keyboard entries and leave the entire SUN display
>available for graphics pane(s).
We used to run GRASS exclusively in the above dual monitor fashion, the
best driver to use for the graphics screen WAS SunCORE. The ease
of SunCORE being that you do not need to actual log into the console
for it to work. Additionally the SunCORE GRASS Driver was many times
faster than using either SunView or X11! Unfortunately SUN longer
supports SunCORE, although it still comes with SunOS 4.1.3 (found in the
"/usr/old" directory and has to be installed from there). It worked just
great on our old SUN 3s (SunOS 4.1.1) and their CG2 & CG4 Frame Buffers,
but we have troubles with our new SPARC Stations (SunOS 4.1.3) when trying
to access the CG6 Frame Buffers. Since SUN no longer supports the SunCORE
System, they will NOT be fixing the CG6 problem (which was multiple
"HW Cursor rop error"s and a very long startup time).
We now use the X11 GRASS Drivers in a similar fashion, but a bit more
involved since you have to log into both the console and the TTY. But
still a good setup (especially for digitizing) as it allows the console
to be full graphics screen, leaving the TTY for the ASCII Terminal
Functions.
Lawrence Houston .....
| Lawrence Houston (HOUSTON at MGM.lan.mcgill.ca) |
| Department of Geography - McGill University |
| GGGGGGG IIIIIII SSSSSSS |
| G G I S S |
| G I S |
| G I SSSSSSS |
| G GGGG I S |
| G G I S S |
| GGGGGGGG IIIIIII SSSSSSS |
Acknowledge-To: <houston at mgm.lan.mcgill.ca>
