RIM
grass
doug at nps.unm.edu
Fri Jun 4 10:05:35 EDT 1993
I'm still hoping to find the apparently simple solution to my problem with "s.db.rim". I'm guessing that the description of my problem is not clear. So I would like to try again.
In the past, that is before compiling GRASS4.1, I was able to bring up the menu driven "s.db.rim". This is very useful wich holds over 2000 archaeological sites.
Now, I'm only able to get this type of response from "s.db.rim"
s.db.rim
OPTION: Name of data base to open
key: database
required: NO
enter option >
What I'm wanting is this type of response from "s.db.rim"
s.db.rim MAIN MENU (V 1.4)
No Data Base Currently Open.
1 Open a data base
2 List available data bases
----------- Retrieve/Output Site Records (0 currently) ---
3 Find sites in proximity to a Target point
4 Query to select site records (SQL)
------- 5 Show selected site records on Terminal
1_ 6 Display maps/selected sites on graphics terminal
------- 7 Output selected site records to Printer or File
8 Create a site_list from selected records
------------------- Add/Edit Site Records -----------------
9 View a single site record
10 Add a new site record
11 Change an existing site record
12 Delete one record or all selected records
------- Other functions -- Shell Command -- Exit ----------
13 Make a new data base & Management Functions
14 Execute a shell command
0 Done -- Exit from s.db.rim
AFTER COMPLETING ALL ANSWERS, HIT <ESC> TO CONTINUE
(OR <Ctrl-C> TO EXIT THIS PROGRAM)
Does anyone have any ideas?? Thanks to those who have offered help.
Doug Bradley
CPSU-UNM Albuquerque
