No subject
Net.Noise owner
news at max.cecer.army.mil
Wed Jun 16 11:59:01 EDT 1993
Newsgroups: info.grass.user
Path: zorro.cecer.army.mil!shapiro
From: shapiro at zorro.cecer.army.mil (Michael Shapiro)
Subject: Re: G_realloc: out of memory
Message-ID: <C8q1qA.Any at news.cecer.army.mil>
Sender: news at news.cecer.army.mil (Net.Noise owner)
Organization: US Army Corps of Engineers Construction Engineering Research Labs
References: <9306071409.AA25785 at nps.unm.edu.NPS>
Date: Wed, 16 Jun 1993 15:58:58 GMT
Lines: 24
In <9306071409.AA25785 at nps.unm.edu.NPS> doug at nps.unm.edu (grass) writes:
> When running r.support on an image I find this error.
> Does anyone know what I can do to run an update on the stats
> for this image?
>Doug Bradley
>UNM-CPSU ALB
The file that r.support is trying to update is cell_misc/<map>/range
which is a one line ascii file with 4 numbers: nmin nmax pmin pmax
(corresponing to the min and max range for the negative and positive
values in your raster map). Try
r.describe -r <map>
The -r option for r.describe doesn't require as much memory and will
tell you the values you need for nmin, nmax, pmin, pmax. Then create
the range file "by hand".
Michael Shapiro shapiro at zorro.cecer.army.mil
U.S. Army CERL (217) 373-7277
P.O. Box 9005
Champaign, Ill. 61826-9005
