No subject
Net.Noise owner news at max.cecer.army.mil
Wed Jun 16 12:04:39 EDT 1993
Newsgroups: info.grass.user
Path: zorro.cecer.army.mil!shapiro
From: shapiro at zorro.cecer.army.mil (Michael Shapiro)
Subject: Re: Dumb Terminals & SUN's
Message-ID: <C8q1zo.At3 at news.cecer.army.mil>
Sender: news at news.cecer.army.mil (Net.Noise owner)
Organization: US Army Corps of Engineers Construction Engineering Research Labs
References: <9306082300.AA15974 at noaacrd.colorado.edu>
Date: Wed, 16 Jun 1993 16:04:36 GMT
Lines: 29
In <9306082300.AA15974 at noaacrd.colorado.edu> caa at noaacrd.Colorado.EDU (Craig Anderson) writes:
> edited the grass4.1/etc/monitorcap file as follows: (1 of 7, x0-x6)
>            /discs/scsi3/grass4.1/dev/fifo.1a \
>            /discs/scsi3/grass4.1/dev/fifo.1b: \
>            /dev/console:any terminal
> when d.mon is run to start a display screen on the SUN monitor, the following
> appears:
>[Error: must start x0 from any terminal    ]("any terminal" read from monitorcap file.
>[You are on /dev/ttya                      ]
>[Please start graphics monitor <x0>.       ]
>[Error - Graphics monitor <x0> not running!]
>[Problem selecting x0.  Will try once more ]
The specification of /dev/console is saying that d.mon must be run
from /dev/console (even though the user message says "any terminal")
Modify the monitorcap entry and remove /dev/console:
>            /discs/scsi3/grass4.1/dev/fifo.1b::any terminal
Michael Shapiro               shapiro at zorro.cecer.army.mil
U.S. Army CERL                (217) 373-7277
P.O. Box 9005
Champaign, Ill. 61826-9005
