4.1 compile probs on RS6000-is this an AIX bug?
Claude Errera
errera at ese.ogi.edu
Fri Jun 18 21:40:32 EDT 1993
Well, I've been trying to compile xgrass for a couple of days
now on an RS/6000 running AIX v3.2.0, and I've run into what
my sysadmin thinks might be a bug in AIX (he has heard rumors
that the loader has some troubles when there are too many external
variables). I thought I'd throw it out to the experts, just in case.
Problem: compilation of XDRIVER falls apart because of undefined
symbols. Here is output from GISGEN:
GISGEN: src/display/devices/XDRIVER/XDRIVER - Fri Jun 18 15:22:14 1993
/mnt/errera/grass4.1/src/display/devices/XDRIVER/XDRIVER
make -f OBJ.ibmr2/make.rules
rm -f OBJ.ibmr2/SWITCHER.o
cc -O -D_NO_PROTO -I/mnt/errera/grass4.1/src/include -DUSE_TERMIO -c SWITCHER.c
mv SWITCHER.o OBJ.ibmr2/SWITCHER.o
rm -f a.out
cc -s OBJ.ibmr2/SWITCHER.o OBJ.ibmr2/Box_abs.o OBJ.ibmr2/Can_do.o OBJ.ibmr2/Color.o OBJ.ibmr2/Cont_abs.o OBJ.ibmr2/Clr_table.o OBJ.ibmr2/Draw_line.o OB J.ibmr2/Get_w_box.o OBJ.ibmr2/Get_w_line.o OBJ.ibmr2/Get_w_pnt.o OBJ.ibmr2/Graph _Clse.o OBJ.ibmr2/Graph_Set.o OBJ.ibmr2/Panel.o OBJ.ibmr2/Plylne_abs.o OBJ.ibmr2 /Polygn_abs.o OBJ.ibmr2/Returns.o OBJ.ibmr2/Serve_Xevent.o OBJ.ibmr2/alloc.o OBJ .ibmr2/command_pend.o OBJ.ibmr2/Raster.o ../../lib/LIB.ibmr2/driverlib.a /mnt/errera/grass4.1/src/libes/LIB.ibmr2/libD.a -L/usr/lib -lX11 -lm
0706-317 ERROR: Unresolved or undefined symbols detected:
Symbols in error (followed by references) are
dumped to the load map.
The -bloadmap:<filename> option will create a load map.
.Font_get
.get_num_colors
.color
The error code from the last failed command is 8.
Make Quitting.
GISGEN failure at STEP: src/display/devices/XDRIVER/XDRIVER
Anybody have any clues? (In case anyone wonders what the extra included
libraries are doing there, it was a desperate attempt to specifically
include all libraries that even mentioned the offending functions. It
made no difference.)
Thanks!
Claude Errera Oregon Graduate Institute
errera at ese.ogi.edu Environmental Science and Engineering
19600 NW von Neumann Drive
PHONE: (503) 690-1063 Beaverton, OR 97006-1999
FAX: (503) 690-1273
