Installing GRASS4.0 on an SGI workstation?
Michael Shapiro
shapiro at zorro.cecer.army.mil
Sat Mar 6 23:10:20 EST 1993
In info.grass.user you write:
COLORS was added to one of the Unix include files after the code was
originally written. This cause a conflict. GRASS4.1 changes this from
COLORS to THE_COLORS (or some other non-conflicting name).
>[]You probably need a -cckr flag.
>Thank you for helping with my compiling problems. The "-cckr" flag did
>indeed take care of many of the compilling errors. Still, I have had to
>edit the GRASS source a bit to remove other errors. As I continue to
>do this, I am wondering if this is typical of the SGI port or if there
>is something else I am missing. For example, here is another error message.
>Is this something you have had to deal with too?
>GISGEN: imagery/i.class - Thu Feb 18 12:36:08 CST 1993
>/work/i1a/GRASS4.0/src/imagery/i.class
> mkdir OBJ
> make -f OBJ/make.rules
> rm -f OBJ/main.o
> cc -O -cckr -I/work/i1a/GRASS4.0/src/libes -DUSE_TERMIO -c main.c
>ccom: Error: ./globals.h, line 28: redeclaration of COLORS
> int COLORS[10];
>*** Error code 1
>Stop.
>GISGEN failure at STEP: imagery/i.class
> o o o o o o o . . . ________________________________ _____=======_T___
> o _____ ||Wes Barris | | wes at msc.edu |
> .][__n_n_|DD[ ====|____ |Research Equipment Inc. dba | |(612) 626-8090 |
> >(________|__|_[___/_____]_|Minnesota_Supercomputer_Center|_|_FAX: 626-1596_|_
> _/oo OOOOOO o` ooo ooo 'o^o^o o^o^o` 'o^o o^o`
>You have an ambitious nature and may make a name for yourself.
Michael Shapiro U.S. Army CERL
Environmental Division
P.O. Box 9005
Champaign, Ill. 61826-9005
email: shapiro at zorro.cecer.army.mil
phone: (217) 352-6511 ext 526
fax: (217) 373-7222
