Reading a vector map into rim
Christine Weiss cmw at nycparks.gov
Thu Mar 11 14:55:06 EST 1993
Hi. I'm having a problem with the .read_vect command in v.db.rim when I try to add the attribute_field (p.11 in the grass reference manual). I'm using this command:
v.db> .read_vect vegetation [attribute_field]
vegetation is my vector map name
attribute_field is the integer field name in my database layout.
I want the attributes from my dig_att file to be put into this field.
When I use this command. I get the following error message:
Unknown field name: [attribute_field]. Data not added.
However, attribute_field is clearly defined in my screen layout as the integer field:
~iattribute_field
Does anyone know what I'm doing wrong?
Thank you,
Ornitte Nagar
Please respond to:  cmw at nycparks.gov
