arc/info grid-files to grass
Anantha Prasad
prasad at ghat.inhs.uiuc.edu
Wed Mar 17 11:12:09 EST 1993
> From grass-lists-owner at max.cecer.army.mil Wed Mar 17 07:01:43 1993
> From: ca4 at aixfile1.urz.uni-heidelberg.de (Stefan Jaeger)
> Subject: arc/info grid-files to grass
> Sender: lists-owner at max.cecer.army.mil
> Reply-To: grassu-list at max.cecer.army.mil
> Date: Wed, 17 Mar 93 13:48:18 CET
> X-Mailer: ELM [version 2.3 PL2]
> Content-Length: 169
> Hello,
> I would like to know which is the best way to convert ARC/INFO grid files
> to GRASS?
> Thanks!
> Stefan Jaeger
> Dept. of Geography
> University of Heidelberg
> Germany
This is the way I do it:
r.out.ascii map=yourmap>yourmap.ascii
yourmap.ascii will have grass header information that needs to be changed to the header arc/info requires. So type "help asciigrid" in Arc and it will tell you the header format that arc/info needs. You need to change the grass header to the arcinfo header by editing yourmap.ascii. Then use, asciigrid in arc.
Anantha Prasad
