Distance analysis
Lars Schylberg
larss at fmi.kth.se
Thu Mar 18 03:33:21 EST 1993
I wrote a little script (r.distance.sh) last year that makes something
that is close to this. I used r.buffer on a clump map (produced by
r.clump). Maybe you could start with this script and modify it for your
needs. This scripts lets the user point on two clumps and then the
scripts computes the shortest distance between those.
The script is included in the end of this message. Please let me know
if you come up with some bright idea concening this. I am allways
interested to see new scritps if you write any concerning this.
I guess you could include the r.clump operation in your script, display
the cateogory map and compute distances on the clump map.
Lars
Lars Schylberg Email: larss at fmi.kth.se
Dept. of Geodesy and Photogrammetry
Royal Institute of Technology (KTH) Tel. +46 8 790 86 33
S-100 44 STOCKHOLM, SWEDEN Fax. +46 8 790 66 10
> I've been searching the grass users archives for scripts that have to do with
> distance analysis. So far I have not found any.
> I want to write a script that would return the shortest distance
> from a specificparcel of land to a specific landuse class e.g. urban
> land.
> r.cost seemed like a good place but if someone out there has some experience
> wih this I would like to hear from you.
> Thanks in advance.
> Bill Jackson
#!/bin/sh
# r.distance.sh
# Author: Lars Schylberg (larss at fmi.kth.se) 921019
# Check if GRASS is running
test "$GISRC" || echo "GRASS is not running" || exit 2
# Evaluate arguments
if [ $# != 1 ]
then
echo
echo Usage: `basename $0`
echo ' clumpmap=mapname '
echo
exit 1
fi
# parse input arguments
for i do
case $i in
clumpmap=*)
CLUM=`echo $i | sed s/clumpmap=//` ;;
clum=*)
CLUM=`echo $i | sed s/clum=//` ;;
c=*)
CLUM=`echo $i | sed s/c=//` ;;
echo ""
echo "Unrecognized option: $i"
echo 'Options: clumpmap=mapname '
echo
exit 1
esac
done
# Check the input arguments
eval `g.findfile element=cell file=$CLUM`
if [ ! "$file" ]
then
echo "$CLUM - clump cell file not found"
exit 2
fi
# Show category map
d.rast $CLUM
# retrieve the two objects by pointing with cursor
echo
echo "POINT WITH CURSOR ON THE FIRST OBJECT"
d.what.rast -1t map=$CLUM > stat
obj1=`cat stat | sed -n '3p' | awk -f: '{print $2}'`
echo
echo "Object 1 has object number $obj1"
echo
echo "POINT WITH CURSOR ON THE SECOND OBJECT"
obj2=`cat stat | sed -n '3p' | awk -f: '{print $2}'`
echo
echo "Object 2 has object number $obj2"
echo
/bin/rm stat
# Determine clostest distance between the two objects
echo "$obj1 = 1" | r.reclass input=$CLUM output=obj1
echo "$obj2 = 1" | r.reclass input=$CLUM output=obj2
MAX_DISTANCE=200
ZONES=`echo $MAX_DISTANCE | awk 'BEGIN { printf "5"}
{ for (i=10; i<=$1; i+=5) printf ",%d", i }'`
r.buffer input=obj1 output=zones dis=$ZONES 2>&1
r.cats map=zones fs=space | sed '1,2d' | awk '{ print $1"="$2 }' > rcrule1
cat rcrule1 | r.reclass input=zones output=dist 2>&1
DIST=`r.stats -q input=obj2,dist | \
awk '{ if ( $1 == 1 && $2 > 0 ) print $2 }' | sed -n '1p'`
echo 'distance = '$DIST
g.remove rast=obj1,obj2,zones 2>&1
