No subject
Net.Noise owner news at max.cecer.army.mil
Fri Mar 26 01:40:37 EST 1993
Newsgroups: info.grass.user
Path: zorro.cecer.army.mil!shapiro
From: shapiro at zorro.cecer.army.mil (Michael Shapiro)
Subject: Re: grid
Message-ID: <C4HH7L.LMn at news.cecer.army.mil>
Sender: news at news.cecer.army.mil (Net.Noise owner)
Organization: US Army Corps of Engineers Construction Engineering Research Labs
References: <9303250118.AA00827 at mqnimbus.cic.mq.edu.au>
Date: Fri, 26 Mar 1993 06:40:32 GMT
Lines: 23
In <9303250118.AA00827 at mqnimbus.cic.mq.edu.au> cathy at mqnimbus.cic.mq.edu.au (Cathy Ciret) writes:
>I send another message,the previous one (grid and contour) was
>probably not clear enought.
>I tried to be able to know visually how many cells I've got in
>my raster maps ,so I need to put a grid with rectangular :
>dimension 4.5 lat,7.5 lon.So far,I couldn't get anything
>like this with d.grid,when I enter the coordonnes in size=values
>it doesn't work.
>My questions are:can we get a grid with rectangular cell,and how?
>Is there another command which give the possibilities to overwrite
>this grid on the raster map(i.e get this grid permanently)
>Thanks for your help.
>Cathy
d.grid only allows square grids. That isn't its only drawback. YOu can't
specify the origin of the grid. The only other tool which will do what
you want is d.mapgraph.
Michael Shapiro U.S. Army CERL
Environmental Division
