BINARY OUTPUT
Ronald Wiemer
ronald at archis.nl
Wed Mar 31 13:41:48 EST 1993
If you would like to import raster files from grass into idrisi, the raster
maps will have to meet the following conditions:
1 Values wiil have to be in the range from 0 to 255 (1 byte / cell)
(you can accomplish this by rescaling (r.rescale)
2 r.rescale does not actually produce a new raster image. You can create one
running r.resample on the rescaled map
3 The files must be in uncompressed format (run r.compress -u)
The cell directory of your current mapset will contain a binary file, which
can be used as an image file in idrisi
Ronald Wiemer
Archis
The Netherlands
