Points within polygons
    GEOL1 at CWU.BITNET
    GEOL1 at CWU.BITNET
    Thu May 13 13:29:00 EDT 1993
If you label the vector polygons then convert to raster at appropriate
resolution, then possibly run r.clump to be sure each raster polygon
has a unique category number, then run s.menu and choose option 8
for the statistics programs, you will get good stuff.
  If you points map is already in raster form, convert back to points
with creative use of r.stats -1g  .
Jim Hinthorne
