v.in.ascii
Wang Song
wang at cast.uark.edu
Fri May 21 10:02:26 EDT 1993
> From grass-lists-owner at max.cecer.army.mil Fri May 21 07:57:18 1993
> Date: Fri, 21 May 1993 08:48:30 -0400
> From: Xin Zhuang <zhuang at access.digex.net>
> Sender: lists-owner at max.cecer.army.mil
> Reply-To: grassu-list at max.cecer.army.mil
> Subject: Re: v.in.ascii
> Content-Length: 255
> Thanks, Cristina.
> I was aware of dig_att. SO I tried v.out.ascii
> "quads" (the simpliest layer in spearfish).
> I had both dig_ascii and dig_att. Then I did
> v.to.rast. I got a layer with one category only.
> I got lost.
> --Xin Zhuang
> zhuang at access.digex.com
Zhuang Xin,
You need to run v.support to build a dig_plus file which is generated
fromm both dig and dig_att files, then try v.to.rast again.
Godd Luck !
Wang Song
