Delivery status: Digitizer thru X-terminal???
-MaiSer-
-MaiSer-.DCRP at mhs.unc.edu
Wed May 26 13:51:00 EDT 1993
A delivery problem was encountered with your message:
Error 101: Unknown user at destination host
Recipient address(es) in error:
ACHET.DCRP at mhs.unc.edu
---- Original text of message follows:
> Question: Can a digitizer be made to function through an X-Window
> display server runing on a PC ?
> INFO: I am runing a Data General AViiON 4625 server with GRASS4.1beta
> (soon to be 4.1) on an ethernet with two PCs runing MS windows 3.1 and
> Control Data Vista-eXceed/W (for windows). The total setup works fine,
> so far. Now, I want to connect a digitizer into the system but would
> perfer to do so through the PCs network connection. Has anyone
donethis
> before and have any info to support this function?
> Thanks.
> Bill Miller
> DataProcessing Coordinator
> 701-224-4288 FAX 3696
> bmiller at dg4600.swc.nodak.edu
> --------End of Unsent Message
Bill M.
------------------------- Original message header:
>From grass-lists-owner at max.cecer.army.mil Wed 26 May 1993 13:49
>X-Envelope-To: ACHET.DCRP at mhs.unc.edu
>Return-Path: <grass-lists-owner at max.cecer.army.mil>
>Received: from mento.oit.unc.edu ([152.2.22.70]) by mhs.unc.edu (SMTPSRV); Wed 26 May 1993 13:49
>Received: from max.cecer.army.mil by mento.oit.unc.edu (NeXT-1.0 (From Sendmail 5.52)/TAS/11-16-88)
> id AA13829; Wed, 26 May 93 13:48:58 EDT
>Received: from amber.cecer.army.mil by max.cecer.army.mil with SMTP id AA06356
> (5.67a/IDA-1.5 for <ACHET.DCRP at mhs.unc.edu>); Wed, 26 May 1993 12:48:15 -0500
>Received: from zorro.cecer.army.mil by amber.cecer.army.mil (4.1/SMI-4.1)
> id AA19410; Wed, 26 May 93 12:41:37 CDT
>Received: from amber.cecer.army.mil by zorro.cecer.army.mil with SMTP id AA04753
> (5.67a/IDA-1.4.4 for <grassu-people at amber>); Wed, 26 May 1993 12:41:36 -0500
>Received: from max.cecer.army.mil by amber.cecer.army.mil (4.1/SMI-4.1)
> id AA19404; Wed, 26 May 93 12:41:35 CDT
>Received: from dg4600.swc.NoDak.edu by max.cecer.army.mil with SMTP id AA06224
> (5.67a/IDA-1.5 for <grassu-list at max.cecer.army.mil>); Wed, 26 May 1993 12:41:34 -0500
>Received: by dg4600.swc.nodak.edu (5.4R2.01/200.1.1.4)
> id AA06145; Wed, 26 May 1993 12:40:35 -0500
>Date: Wed May 26 12:40 cdt 1993
>From: bmiller at dg4600.swc.nodak.edu (Bill Miller)
>Message-Id: <112670010243923EMU0000 at dg4600.swc>
>Sender: lists-owner at max.cecer.army.mil
>Reply-To: grassu-list at max.cecer.army.mil
>Precedence: Bulk
>Subject: Digitizer thru X-terminal???
------------------------- End of message header:
