d.mon - Problem
    Darrell McCauley
    mccauley at ecn.purdue.edu
    Tue Nov  9 14:28:13 EST 1993
Kym,
I reproduced this error by removing $LOCATION/WIND. See if this
file exists. (You see, it needs to know how to transform your map
coordinates to the monitor coordinate system.)
The problem is not with the XDRIVER, but your database.
KLENKUS1 at VAXC.STEVENS-TECH.EDU (KLENKUS1 at VAXC.STEVENS-TECH.EDU) writes on 09 Nov 93:
>Graphics driver [x0] started
>ERROR: region for current mapset is not set
>	   run "g.region"
>Problem selecting x0. will try once more.
>Is this a problem that I have set something wrong in
>selecting the database or problems with my XDRIVER?
