Site Data
Craig Anderson caa at noaacrd.Colorado.EDU
Tue Nov 30 19:19:49 EST 1993
Fellow GP/GU's
	I have a problem as usual with site data, seems to be a reoccuring
problem.  I would like to get some site data into GRASS in the following format:
East         North        Attrib
-111:25:12   45:29:51     #1
	Thus far, the only way I can get s.in.ascii to work is by changing the
format to:
East	     North        Attrib
-111.2512     45.2951     #1
	Needless to say these are not quite the same position.  One being in
DDMMSS and the other in Decimal Degrees.  Question is, why can't the blasted
thing read in ddmmss format?  G.region seems to be correctly set but I get a
format error every time I run s.in.ascii.
Thanks, Craig
caa at noaacrd.colorado.edu
----- End Included Message -----
to convert DDMMSS to Decimal Degrees
(Degrees) + ( Minutes / 60 ) + ( Seconds / 3600 )
so -111:25:12 = -111.42    not -111.2512
This doesn't address your question but it should give you better results
_____________________________________________________________________
|  Tom Nelson                                                        |
|  Corps of Engineers                                                |
|  Fort Worth, Texas                                                 |
|  (817) 334-2095                                                    |
|  tom%alla@[155.84.92.2]                                            |
|____________________________________________________________________|
