ps.map
Dr. A.R. Palmer
plad at hippo.ru.ac.za
Tue Oct 5 05:56:18 EDT 1993
Using ps.map, I have successfully generated the spearfish soils coverage
plus text and roads, as provided in the example in the manual. Output
goes to level 2 Calcomp A4 Colormster Plus. However, when I create *.ps
files for southern African combinations of raster (NDVI's) and map
vectors (Acocks map), the *.ps file is created but does not print. The
raster coverage does print on its own, but once I add the vector, *.ps
file is created but does not print. This same raster coverage is visible
when displayed using d.display. The spearfish data are in UTM
projection, my coverage is lat-long.Is ps.map compatible with lat-long
projections ?
Thanks
Tony
PS. Apologies for subscribing so badly -selected the wrong alias.
Dr A.R. (Tony) Palmer | Roodeplaat Grassland |Tel: Intl-27-461-22638
Principal Agricultural| Institute |Fax: Intl-27-461-22398
Researcher | PO Box 101 |e-mail:plad at hippo.ru.ac.za
| 6140 Grahamstown |
| South Africa |
