GRASS graphics monitor problem
Phil.Watson at newcastle.ac.uk
Thu Oct 7 09:22:55 EDT 1993
>I am trying to run grass4.0 on a SUN sparc IPX, and cannot
>get the graphics monitor work properly. It keeps giving me
>the following message:
> GRASS 4.0 > d.mon start=x0
> Graphics driver [x0] is already running
> Error - Could not complete locking process for monitor <x0>.
> Lock file is /applications/grass4.0/locks/dolphin/:0.0/x0
> Problem selecting x0. Will try once more
> ERROR - eof from graphics monitor.
>I wonder if any of you had this problem before. It would be greatly
>appreciated if anyone can give me a hint how to fix it.
the easiest way is to log in as root, change directory to
/applications/grass4.0/locks/dolphin, make sure no-one is using
grass monitors on that machine, and remove all the files an
sub-directories from there down.
To be a bit safer you could just remove /applications/grass4.0/locks/dolphin/:0.0/x0
or just use another monitor .....
phil
