r.out.xyz (Was: GMT & netCDF files)
Darrell McCauley
mccauley at ecn.purdue.edu
Tue Oct 26 14:54:25 EDT 1993
amante at grouse.pnl.gov (amante at grouse.pnl.gov) writes on 26 Oct 93:
> I lost the intent of the original message. Were you going to try to
Craig was trying to put info into something else.
>export a raster file into a file in just an x, y and z format so that it could
>be used? If so, I'm all for it. (Then GNUPLOT could use it, right???).
Actually, for g.gnuplot, the following works well
(you have to insert a few blank lines).
r.stats -1x $1 | awk '$2 != row{print "";row=$2}{print}'
--Darrell
P.S. you may want to reduce your resolution (g.region), depending.
