complement of v.prune?
Susan Huse
sue at ced.berkeley.edu
Thu Apr 7 19:42:42 EDT 1994
> From grass-lists-owner at max.cecer.army.mil Thu Apr 7 16:27:52 1994
> Date: Fri, 8 Apr 94 08:58:55 EST
> From: simon at artemis.earth.monash.edu.au (Simon Cox)
> Sender: grass-lists-owner at max.cecer.army.mil
> Reply-To: grassu-list at max.cecer.army.mil
> To: grassu-list at amber.cecer.army.mil
> Subject: complement of v.prune?
> Content-Length: 1195
> No responses first time around, so I'll ask again!
> Is there a way to do the opposite of v.prune - ie ADD vertices
> along lines to keep them to a set spacing?
> I suspect this
> could be done by exporting the file using v.to.sites using the
> -i option, and then re-importing the sites file into a vector
> (I do not look forward to editting the ascii file, however!) -
> except that the -i flag in v.to.sites doesn't work for me!
> (I've filed a bug report).
> Thanks Simon Cox
> ______________________________________________________________________________
> from May 1st (or thereabouts) __ L Dr Simon Cox
> CSIRO Div. Exploration & Mining ,~' L_|\ VIEPS Dept of Earth Sciences,
> 39 Fairway, PO Box 437, ,-' \ Monash University, Clayton
> Nedlands, WA 6009, Australia ( soon \ Vic 3168, Australia
> Phone +61 9 389 8421 X<~~~~~~~~~ / Phone +61 3 905 5762
> Fax +61 9 389 1906 L,~' "\_x/ Fax +61 3 905 5062
> s.cox at dem.csiro.au u simon at artemis.earth.monash.edu.au
The only way I know would be to mess with the ascii, sorry. Use awk.
It may be a pain, but if v.to.sites -i doesn't work I don't know of a
better way.
You could do it as a sites file or as a dig_ascii file.
If sqrt ( (x2 - x1)^2 + (y2-y1)^2 ) > threshold then newE=0.5(x2+x1);
newN=0.5(y2+y1) printf("%s %s\n%s %s\n", newE, newN, x2, y2) >
"filename". Or something to that effect. You'd also need a
test loop to be sure that the distance between point2 and newE/N is
less than your threshold.
-sue
