format dwg?
    Malcolm Williamson
    malcolm at cast.uark.edu
    Tue Apr 12 15:30:03 EDT 1994
This is a standard AutoCAD format which is not supported for import into GRASS.
You'll need to load it back on an AutoCAD system, and save it again as dxf
format. You'll then be able to use v.in.dxf
>  I have vector data in file with extension dwg? Does anyone know
>  about this format and conversion means to grass vector file?
>  TIA Peter  pom at llnl.gov
Malcolm D. Williamson - Research Assistant       E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies      Telephone: (501) 575-6159
Ozark Rm. 12                                        Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
