surface_deviations
Irochka
kosinov at uxa.cso.uiuc.edu
Wed Apr 20 14:19:21 EDT 1994
In info.grass.user you write:
>Helena wrote:
>If you use the new s.surf.tps which Irina has just put
>on moon for creating a raster file you can use the option to
>output deviation site file which is computed simlutaneously
>with the somputation of the resulting raster map.
>Where is this new s.surf.tps? I looked on /incoming on moon.
>Is it a different name?
>Thanks
>Kym M. Lenkus
>Davidson Laboratory
You have to get the whole interpolation library, uncompress it and unpack it.
It is called interp_lib.shar.Z
Irina
