Monitor colors
martijn at scanner.frw.uva.nl
Mon Aug 8 04:43:43 EDT 1994
One other reason for Grass images to contain less greyscale values than
they should is that they really do. That is, you either never had 256
different values in the image or you lost them during import/conversion
procedures. The first thing to do is to query your Grass image using
"r.cats" to find out if there really are only 31 values left. If this
proves true, and you're POSITIVE that the original image contained more
different values than that, you must have lost them somewhere. This means
you have to check every step along the way. Hopefully you will discover
that you inadvertently resampled the image - the `save at original size'
checkbox in Xv comes to mind as a plausible cause.
P. Martijn van Leusen
Institute of Prehistory, University of Amsterdam martijn at scanner.frw.uva.nl
