Grassu archives searching?
martijn at scanner.frw.uva.nl
Fri Aug 12 07:17:28 EDT 1994
Hi Ania,
There's no really user-friendly way, but the following works:
1) Get the archive files from the moon and put them in one large file
2) Use UNIX shell commands to search the file, eg:
cat <file>|grep ubj|sort > tmpfile (to get sorted list of subject lines)
vi <file> and use pattern-searching capability (to search for
subjects of interest)
you can also assign line numbers to <file> to facilitate searching...
3) In my Grass Beginner's Manual I have tried to summarize most of the
discussions on grassu-list. You can get it off moon if you don't already
have it.
P. Martijn van Leusen
Institute of Prehistory, University of Amsterdam martijn at scanner.frw.uva.nl
On Fri, 12 Aug 1994, Ania Oldak wrote:
> Dear Netters,
> is there any way to search ?through the grassu-list archives at
> the max.cecer.army.mil site?
> Many problems haunting a grass novice were probably grilled there
> zillions of times.
> Cheerio, Ania
