Grassu archives searching?
    Ronald Thomas
    ront at picea.CNR.ColoState.EDU
    Fri Aug 12 09:09:12 EDT 1994
In article <199408120533.AAA13517 at max.cecer.army.mil> grassu-list at max.cecer.army.mil writes:
>Dear Netters,
>is there any way to search ?through the grassu-list archives at
>the max.cecer.army.mil site?
>Many problems haunting a grass novice were probably grilled there
>zillions of times.
>Cheerio, Ania
Don't know about searching achives on the "moon"; best bet is to retrieve
the achives and search at your own site.  Your comments about some
questions being asked (& answered) over & over are right on.
Here is a script I use to query a copy of the archives that I keep:
#!/bin/sh
#This script "grassu94" searches for a 'keyword' in the following
# file:  grassu.92.gz.  If it finds whatever you requested, the
# script then prints that line or lines out on the terminal.  If it doesn't
# find what you asked for, the script will tell you that it can't be found.
# usage: grassu94 'keyword'
if test $# -gt 0
then
  arg="$*"
  gzcat $HOME/mail/grassu.94.gz | grep -i -n "$arg" | more
  es=$?
  if test $es = '0'
  then
    exit 0
  else
    echo "$*" not found in grassu.94 file.
    exit 1
  fi
else
  echo You have not entered anything to look up.
  exit 2
fi
The following script file can be used to delete a LOT of extraneous header
lines that unfortunately come with the archives -- I estimate this reduces
the size of the achives by 30%.  Of course, UNIX compress of GNU gzip
should be used to keep the 'cleaned' file as small as possible, but that's
a personal decision.
#clean
#usage: clean 'file'
ex $1 << EOF
:g/^Re/d
:g/^	id/d
:g/^  (/d
:g/^Se/d
:g/^Appar/d
:g/^X/d
:g/^In-Reply/d
:g/^Status:/d
:g/^Errors-To/d
:g/^Pre/d
:g/^From lists/d
:g/^Message/d
:g/^To:/d
:g/^From grass/d
:g/^Content/d
:g/^Organization/d
:g/^Received/d
:wq
EOF
Ronald Thomas                                Email: ron_thomas at nps.gov
 Natural Resource Spec. (GIS)         ^^^    Phone: 303-586-1292
  Resources Management Division  ^^  ^^^^^   FAX: 303-586-1310
   Rocky Mountain National Park ^^^ ^^^^^^^  Estes Park, CO  80517
