SG3d
Rebecca Scheckler
rebecca at vt.edu
Tue Aug 16 08:14:06 EDT 1994
>> Hello,
>> I am trying to run SG3d. I get the following error and SG3d will
>> not run.
>> ERROR: GISRC - variable not set
>> Can anyone tell me what this GISRC variable is? Thanks.
>> -Stephen Dzurenko
>$GISRC is set when you start up GRASS; the variable $GISRC is a file in
>your home-directory where information concerning your GRASS setup is
>stored. It's usually called $home/.grassrc and contains indispensable
>information like the GISDBASE, LOCATION_NAME and MAPSET variables that
>GRASS needs in order to find your maps. I seem to remember a discussion
>on this list a long, long time ago about starting GRASS programs outside
>the GRASS-shell; maybe there's someone with a fresher memory than mine
>that can tell us more about that.
The last GrassClippings has this information provided by W. Frederick Limp
and Malcom Williamson.
"1. set the following environmental variables:
GISRC(should be your_home_dir_path/.grassrc)
GISBASE (where the GRASS bin, etc, and scripts directories are found)
GIS_LOCK (usually set to the processid of the start up shell script: I
would use the pid of the current shell)
GISDBASE (the database entry on the GRASS start up page )
LOCATION (the Database and the location of the mapset)
MAPSET (just the mapset name)
Add the following paths to your PATH:
$GISBASE/bin
$GISBASE/scripts
$GISBASE/garden/bin
If these are set you can type any GRASS caommand and it should execute."
I have done this in a shell script and it has worked without any problems.
Rebecca Scheckler rebecca at vt.edu(internet)
Senior Programmer/Analyst rebeccas at vtvm1(bitnet)
Information Systems and Insect Studies fax: 703-231-9131
Virginia Tech phone: 703-231-7216
Blacksburg, VA 24061-0319
