Stitching together rasters
    KLENKUS1 at VAXC.STEVENS-TECH.EDU
    Thu Aug 18 11:48:41 EDT 1994
Steve,
Yes, you can 'stitch' together your raster maps.  The
trick is to have enough overlap of the map to provide
a nice edge to cut by using r.mapcalc.
I have used this technique with s.surf.tps deviding
the area up into two section.  You do need a significant
amount of overlap but the results can be worth it
in time saved.
Hope this helps.
Kym M. Lenkus
DAVIDSON LABORATORY
Stevens Institute of Technology
