r.water.drain/outlet
Morris Trimmer
mtrimmer at liberty.uc.wlu.edu
Mon Aug 22 11:11:50 EDT 1994
oops . . . I ment to write r.water.outlet not r.water.drain in the message below:
> Users,
> I must be missing something conceptually or software wise . . .
> I am trying to find the drainage basin above a point in a stream. I can not
> get r.watershed to do this and it does not seem to be intended to. Though
> r.water.drain is in my on-line manual and looks like it is exactly what I need,
> the program itself is not in my grass version 4.1. Should it be? Is it a
> contributed program that I need to compile? Or, is there another way to go
> about this. Thanks ! ! !
> Morris
