g.setproj
Simon Cox
s.cox at dem.csiro.au
Fri Aug 26 00:50:28 EDT 1994
>>Can someone explain how g.setproj works. According to the man page, it
>>should prompt for the projection. In practice howver, it seems to read
>>the proj from DEFAULT_WIND. The problem I'm finding is that the only
>>valid proj: values are:
>> 0:(xy)
>> 1:(utm)
>> 2:(state plane)
>> 3:(ll)
>>and g.setproj doesn't like anything else. So how do I get nifty
>>projections like aea,lcc,merc,tmerc? Note this is the same list that
>>comes up for me when making a new location. Shouldn't that include all these
>>projections?
>Yes it should. This is a severe weakness in GRASS.
>Tim
... which was largely rectified in GRASS4.1 using proj:value "99" ("other")
which allows a _large_ selection of projections. I use Lambert Conformal
Conic and Albers Equal Area regularly. I suggest you update too.
____
__________________________________________________________________
Dr Simon Cox __ L
CSIRO Exploration & Mining ,~' L_|\ Australian
39 Fairway, PO Box 437, ;-' \ Geodynamics
Nedlands, WA 6009, Australia ( \ Cooperative
Phone +61 9 389 8421 + ___ / Research
Fax +61 9 389 1906 L~~' "\__/ Centre
s.cox at dem.csiro.au 7
