FW: Dynamically changing window size
Conn Copas
cvc at itd.dsto.gov.au
Thu Dec 15 23:00:32 EST 1994
More thoughts on this problem:
> However, how can changes in the .grassrc file take effect WITHOUT
> exiting and re-starting GRASS? A simple Bourne shell script (inspired by
> GIS.sh) as follows does NOT do the job UNLESS Zhian exits, then restarts
> GRASS:
A quick-and-dirty solution, provided that one invariably wishes to start a
monitor after using this script to change sizing variables, is to embed the
'd.mon' command within the script itself, and feed it the necessary
arguments.
Conn V Copas
Information Technology Division
Defence Science and Technology Organisation
PO Box 1500
Salisbury tel: +61 (0)8 25 95349
SA 5108 fax: +61 (0)8 25 96781
Australia e-mail: cvc at itd.dsto.gov.au
