Intersite distances
Rick Thompson rick at cast.uark.edu
Wed Feb 2 13:00:06 EST 1994
Hello,
  One way could be to convert the site file to a vector file (I have a script
you could modify to do this.), then use v.report to measure the distance.
Individual vector segments could be assigned a different category number
with a little work in the script so that the final output measured the
distance between each 2 points (if needed). Rick
> Anyone,
> How can one compute the distance between sites in a site_lists file with
> GRASS 4.1?
> Cliff Behrens
Rick Thompson-   Research Assistant           E-mail: rick at cast.uark.edu
Center for Advanced Spatial Technologies      Telephone: (501) 575-5736
Ozark Hall Rm. 12                             Fax: 575-3846
University of Arkansas
Fayetteville, AR 72701
