Intersite distances
W. Fredrick Limp fred at cast.uark.edu
Wed Feb 2 16:13:54 EST 1994
I'm this thread a little late but you might want to send e-mail
to Bob Harris (boss at cast.uark.edu) he worked up a little
program to compute "site neighborhoods" by computing the nearest
neighbor for s set of x sites and z "centers".  I think the
code was C and use GRASS site lists
> Hello,
>   One way could be to convert the site file to a vector file (I have a script
> you could modify to do this.), then use v.report to measure the distance.
> Individual vector segments could be assigned a different category number
> with a little work in the script so that the final output measured the
> distance between each 2 points (if needed). Rick
> > Anyone,
> > How can one compute the distance between sites in a site_lists file with
> > GRASS 4.1?
> > Cliff Behrens
> Rick Thompson-   Research Assistant           E-mail: rick at cast.uark.edu
> Center for Advanced Spatial Technologies      Telephone: (501) 575-5736
> Ozark Hall Rm. 12                             Fax: 575-3846
> University of Arkansas
> Fayetteville, AR 72701
W. Fredrick Limp,   Director                     FAX: (501) 575-3846
CAST, Center for Advanced Spatial Technologies   TEL: (501) 575-6159
12 Ozark Hall, University of Arkansas
Fayetteville AR 72701                             fred at cast.uark.edu
