Warning messages v.support
Bonnie Weller
weller at zorro.cecer.army.mil
Tue Feb 15 18:45:37 EST 1994
I get that message sometimes too. The only way I have gotten rid of them is
when I exit v.digit and am asked if I want to compress the data I select yes
(the default is no) v.clean does not work for me as it doent seem to delete
the deleted labels. Compressing the atts file seems to work. If you know of
a way to compress the atts file without going through v.digit, please let me
know. I only seem to get this prompt when I make some sort of change to the
dig file, so sometimes I have to go in, add a line and then delete it. Then
when I exit digit I get the compression prompt.
Hope this makes sense and helps. If not e-mail me and I'll try to explain it
better.
Bonnie
weller at kazak.nmsu.edu
