Line thickness in ps.map
    Malcolm Williamson
    malcolm at cast.uark.edu
    Fri Feb 18 14:35:45 EST 1994
Steve,
I believe that this is fixed in the newest version of ps.map on the moon
(incoming). You can select a width of 0 in it (I think!). If not, contact
me directly...
> Is there anyway to get the line thickness reduced when using the 'ps.map'
> command?
> I've set the width to 1, but on our Laserjet IV the lines must be > 1mm
> thick. The text is fine though, even down to 4 point, so the printer and
> Postscript can cope, just that 'ps.map' seems to set lines very thick.
> Is this something to do with the screen vs. printer resolution ?
> Steve Culshaw
> NRA North West
> e-mail : nra at cix.compulink.co.uk (general usage)
> or         sculshaw at cix.compulink.co.uk (Private - only checked at best
> weekly)
Malcolm D. Williamson - Research Assistant       E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies      Telephone: (501) 575-6159
Ozark Rm. 12                                        Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
