How to calculate center of area
Rick Thompson rick at cast.uark.edu
Fri Feb 25 12:41:41 EST 1994
Dan,
  The only thing I've seen that shows a centroid is in output from v.area.
Should you convert your raster map through r.poly to a vector map, v.area
could be checked for viability. Rick
> How does one calculate the center of an irregularly shaped area
> in a raster map in GRASS4.1?
Rick Thompson-   Research Assistant           E-mail: rick at cast.uark.edu
Center for Advanced Spatial Technologies      Telephone: (501) 575-5736
Ozark Hall Rm. 12                             Fax: 575-3846
University of Arkansas
Fayetteville, AR 72701
