d.rast.edit problem with zoomed resolution
George Taylor
oregon at chaos.ATS.ORST.EDU
Mon Feb 28 16:20:16 EST 1994
A bug fix for this problem can be found on machine moon
in the incoming directory. I had the same problem and the
fix solved it.
Wayne Gibson
Oregon State University
> I am having problems editing raster files using d.rast.edit on
> my SGI IRIS (4D-35TG Model running IRIX 4.0.1). If I don't zoom,
> the edit option works OK, but when I zoom first and then edit, I
> get the following error message:
> | Creating temporary edit file |
> +--------------------------------------- 100%
> ERROR: current window resolution does not match cell layer's resolution
> | d.rast.edit aborts |
> Before I use d.rast.edit, I set my region using g.region rast=image_file
> and after d.rast.edit aborts, I check the region and the zoomed
> region has EXACTLY the same resolution as the original region.
> Any help is greatly appreciated - thanks in advance!
> John C Talcott talcott at trg.saic.com
> Science Applications Intl. Corp. (SAIC)
> 10260 Campus Point Drive
> San Diego CA 92121
> (619) 546-6447
