DXF files from ARC/INFO
    NYC Dept. of Environmental Protection
    nycdep5 at transit.nyser.net
    Mon Jan  3 10:25:01 EST 1994
Hello, Olga!
I suggest that you convert DXF text into arcinfo format and store it
as a label file. Then you use arcdlg command and create DLG file with
labels, containing your text. Then you use in GRASS command v.import
and just do it!
Happy New Year! S Novym Godom!
Yuri!
On Thu, 30 Dec 1993, Olga Waupotitsch wrote:
> In info.grass.user you write:
> >Hello Grassers,
> >I've been importing an Arc/Info DXF file into GRASS. I'm under the impression that text
> >from the Arc/Info coverage can be imported into GRASS.  When I convert the file into
> >a GRASS vector using 'v.in.dxf,' all I get are the "boxes" that surround the text.
> >Well, I'm not too interested in "boxes."  I would like to see the text! Can this be done?
> >The text is in the Arc/Info dxf file...it can be viewed. The program v.cadlabel is returning
> >an error message saying "Textfile line 999 NOT labelled" - is this significant?
> >Any ideas folks?
> >THANKS!
> >Ron Howard  (rlh at gasco.com   ph. (503)244-1053 ext 4350)
> I would like to see what the problem here is.
> Can you please ftp the dxf file to moon.cecer.army.mil
> (grass/incoming) so that I can play with it?
> Thank You!
> Olga
