bilinear/cubic convolution
Darrell McCauley mccauley at ecn.purdue.edu
Mon Jan 3 23:23:44 EST 1994
Chris W Skelly (gewcs at jcu.edu.au) writes on 4 Jan 94:
>> Hello all. I would like to use bilinear interpolation or cubic
>> convolution interpolation to do some cross validation when
>> interpolating site data to raster format. My site data are scattered
>I am not sure if I understand you, but if you are going from site
>to cell and you use something like idw or krig the absolute distance
>from the site position to the cell center is used in the
The interpolation knows nothing about the site in question.
See below.
>interpolation. The actual point ceases to exist at the end of the
>day so whether it lines up with a cell centre or not is irrelavent.
>If you want exact interpolation (ie you want that specific
>point value to exist in the cell layer) they you just weight it
>appropriately.
>Can you explain why scattered data is a problem, I think I am
>missing something...
When doing cross validation, I REMOVE some of the original data before
doing the interpolation [using s.kcv].  Point c is of the set of
removed points.
Then, I interpolate to a particular resolution. That gives me my
estimate (Point %). Here are two cells of my raster map with
the site overlayed.
           ____|_____________|_____________|___
               |    c %      |      %      |
To get an error estimate:
1. nearest cell says subtract 'c' from the value of the left cell.
2. bilinear interpolation uses four neighboring cell values (2x2)
   to do 3 linear interpolations and get an approximate value at 'c'
3. cubic convolution uses 16 (4x4) surrounding cells, does some
   convolutions, etc.
With an infinite amount of disk space and time, I could
interpolate to an infinitely small cell size and use method #1.
[The real problem is that I'm using some canned interpolation
 software for which I do not have source code. Therefore, I cannot
 get estimates at precise points :( ]
I hope this clears things up.
--Darrell
