No subject
Bill Hargrove hnw at mtqgrass.ESD.ORNL.GOV
Tue Jan 4 16:00:50 EST 1994
Hi Kym:
     The 4.1 version of the s.surf.tps program writes a (huge) scrambled up
temporary file under .tmp in your mapset while it is printing the percent
completed.  Then, unfortunately, it tries to G_calloc up a lot of memory to
unscramble the completed splined raster.  This is unfortunate because you
never know until its too late (and you've already splined the whole
surface) that your machine doesn't have enough memory to unscramble the
temp file.
     irina at zorro.cecer.army.mil has a newer version that will let you know
up front if you are biting off more than you can chew.  Or you can just
spline a smaller area with the old 4.1 release version.
                              Good luck,
   ____                          Oak Ridge National Laboratory
    /  )      /  /      /  /     Environmental Sciences Division
   /--<   o  /  /      /--/      P.O. Box 2008, M.S. 6038
  /___/__<__/__/_     /  / _     Oak Ridge, TN  37830-6038
William W. Hargrove              (615) 574-1902
hnw at mtqgrass.esd.ornl.gov        (615) 576-8646 (fax)
