converting DLGs
Wang Song
wang at cast.uark.edu
Tue Jan 11 15:46:36 EST 1994
This could be a significant problem because the standard and optional
formats are quite different. The standard format is a direct character
representation of the binary archival DLG, explicit topological linkages
are contained only in the line elements; The optional format was designed
strictly for data interchange. Because topological linkages are explicitly
encoded for all lines, nodes, and area elements, a polygon data structure can
be easily created.
The file headers are significantly different. The standard format uses
Cartesian coordinate system with the parameters of a transformation from
internal file coordinates to UTMs given in the file header, while the optional
format are using the UTM coordinate system directly for each pair of coordinates
in the DLG files.
From my understanding, it will be hard to convert the standard format
of DLGs into GRASS without significant change in source code or modification of
the DLG files significantly.
USGS folks may be able to provide more helps to convert DLGs from
standard format into the optional format.
Song Wang
CAST/NCRI Phone: (501) 575-6159
12 Ozark Hall Fax: (501) 575-3846
University of Arkansas E-Mail: wang at cast.uark.edu
Fayetteville, AR 72701
> Hello GRASS Users,
> I made the mistake of ordering USGS DLGs in standard format
> instead of optional format. Is there any way to convert standard
> format DLGs to GRASS files? I would like to convert them without
> losing the labels.
> Thanks,
> John Nugent
