Problems with xgrass4.1 binary version
Ken Sibley
ksibley at ncg.scs.ag.gov
Fri Jan 14 12:04:28 EST 1994
> Hello Ken!
> >From info.grass.programmer it seems like you know how xgrass is
> working, so I would like to ask you a question.
> My name is Terje Midtboe. I have installed the
> new binary-version of grass4.1 on a SPARC station.
> We are using X11 windows-system.
> It seeems to work, BUT a lot of warning messages is showing up at the
> window where I started xgrass. I guess it is only a detail I need to
> fix. Can you explain how to make the program run
> without these warnings.
> Example of the warnings:
> /usr/local/grass% xgrass4.1
> Warning: translation table syntax error: Unknown keysym name:
> osfActivate
> Warning: ... found while parsing '<Key>osfActivate:
> ManagerGadgetSelect() '
> osfSelect
> Warning: ... found while parsing ' <Key>osfSelect:
> Warning: translation table syntax error: Unknown keysym name: osfHelp
> Warning: ... found while parsing ' <Key>osfHelp:
> ManagerGadgetHelp() '
> osfBeginLine
> In the spring of 93 I imported an earlier compilation of xgrass4.1
> that worked fine, without any warnings.
> Terje
> Terje Midtboe
> Division of Surveying and Mapping Phone: +47 73 59 45 83
> University of Trondheim Fax: +47 73 59 46 21
> N-7034 TRONDHEIM E-mail: terjem at iko.unit.no
> NORWAY
Terje,
I think we just figured this problem out with a little help from our notes.
The following is from a message by Andrew Hertz:
>My understanding is that the openwindows XKeysymDB will not work, you
>want the OSFmotif key mappings. I used the XKeystmDB that's in the xgrass
>source directories ($GIS/src/xgrass). If you've only downloaded the
>binaries, I've put a copy of the XKeystmDB in grass/incoming at
>max.cecer.army.mil. I believe this file MUST be placed in /usr/lib/X11
>because the static binaries have Motif embedded within them and they
>are looking explicitly for /usr/lib/X11/XKeysymDB.
>(You can check this by issuing the command:
> strings xg* | grep XKeystmDB
>in the directory where the xgrass binary executables reside.)
>Changing your path won't help you in this case.
>I hope this helps...
>Andrew Hertz
>hertz at geog.psu.edu
Most of this seems to be correct, but the XKeysymDB file does not
necessarily need to be in /usr/lib/X11. What we found is that
you must place the XKeysymDB file in the directory that returns from
the strings command. We were working on xdigit specificaly (note: using
strings xg*... will not catch xdigit. Use strings xdgit ... for this)
and our path is /grass.src/X11R5/lib/X11/XKeysymDB. This seems to
indicate that it requires the keysym file to be in the exact location
when running that existed when being compiled even if it is a different
machine.
If you have any further questions I will try to help.
Ken Sibley
USDA-SCS
