Problems with xgrass4.1 binary version
Terje Midtboe
Terje.Midtboe at iko.unit.no
Mon Jan 17 06:03:59 EST 1994
Ken
>> Hello Ken!
>> From info.grass.programmer it seems like you know how xgrass is
>> working, so I would like to ask you a question.
>> My name is Terje Midtboe. I have installed the
>> new binary-version of grass4.1 on a SPARC station.
>> We are using X11 windows-system.
>> It seeems to work, BUT a lot of warning messages is showing up at the
>> window where I started xgrass. I guess it is only a detail I need to
>> fix. Can you explain how to make the program run
>> without these warnings.
>> Example of the warnings:
>> /usr/local/grass% xgrass4.1
>> Warning: translation table syntax error: Unknown keysym name:
>> osfActivate
>> Warning: ... found while parsing '<Key>osfActivate:
>> ManagerGadgetSelect() '
>> osfSelect
>> Warning: ... found while parsing ' <Key>osfSelect:
>> Warning: translation table syntax error: Unknown keysym name: osfHelp
>> Warning: ... found while parsing ' <Key>osfHelp:
>> ManagerGadgetHelp() '
>> osfBeginLine
>> In the spring of 93 I imported an earlier compilation of xgrass4.1
>> that worked fine, without any warnings.
>> Terje
>> Terje Midtboe
>> Division of Surveying and Mapping Phone: +47 73 59 45 83
>> University of Trondheim Fax: +47 73 59 46 21
>> N-7034 TRONDHEIM E-mail: terjem at iko.unit.no
>> NORWAY
>Terje,
>I think we just figured this problem out with a little help from our notes.
>The following is from a message by Andrew Hertz:
>>My understanding is that the openwindows XKeysymDB will not work, you
>>want the OSFmotif key mappings. I used the XKeystmDB that's in the xgrass
>>source directories ($GIS/src/xgrass). If you've only downloaded the
>>binaries, I've put a copy of the XKeystmDB in grass/incoming at
>>max.cecer.army.mil. I believe this file MUST be placed in /usr/lib/X11
>>because the static binaries have Motif embedded within them and they
>>are looking explicitly for /usr/lib/X11/XKeysymDB.
>>(You can check this by issuing the command:
>> strings xg* | grep XKeystmDB
>>in the directory where the xgrass binary executables reside.)
>>Changing your path won't help you in this case.
>>I hope this helps...
>>Andrew Hertz
>>hertz at geog.psu.edu
>Most of this seems to be correct, but the XKeysymDB file does not
>necessarily need to be in /usr/lib/X11. What we found is that
>you must place the XKeysymDB file in the directory that returns from
>the strings command. We were working on xdigit specificaly (note: using
>strings xg*... will not catch xdigit. Use strings xdgit ... for this)
>and our path is /grass.src/X11R5/lib/X11/XKeysymDB. This seems to
>indicate that it requires the keysym file to be in the exact location
>when running that existed when being compiled even if it is a different
>machine.
>If you have any further questions I will try to help.
>Ken Sibley
>USDA-SCS
>ksibley at ncg.scs.ag.gov
Thank you very much for your help. That's right, the binary version
requires the XKeysymDB file to be situated at
I have tried it and it works fine. But it is a little bit messy to
make this path on several computers. Is there anybody who knows how to
avoid this problem?
Terje
Terje Midtboe
NORWAY
