I may be confused, but I expected the rainbow color table to go the reverse of the old "ROY G BIV" sequence, but it seems that green gets assigned to lower values than does blue, which doesn't follow if the sequence is VIB G YOR. Can someone explain? I used r.colors to select the rainbow table. Bill Baker bakerwl at uwyo.edu
