HELP NEEDED -- HOW TO READ A TM FILE WITHIN GRASS
Wang Song wang at cast.uark.edu
Fri Jan 21 12:48:24 EST 1994
	Routines available in GRASS4.1:
	(1) Load TM imagery with "i.tape.tm";
	(2) Load SPOT imagery with "i.tape.spot";
	(3) If you encounter a different tape formats which cannot be handled
	    by above commands, use "i.tape.other".
	"i.tape.other" is a more generic command to read different kind of the
imagery. This command allows you read either from a tape or a disk file. The
only thing you should aware before running "i.tape.other" is that you must
understand what are exactly on the tape and file format.
	If you have any problems, write directly to me, I would like to send you
more details.
Song Wang
CAST/NCRI
University of Arkansas
Fayetteville, AR 72701
> Thanks in advance for your attention and help.
> Could some kind heart provide me with some hints about how to read a TM or
> SPOT image file into GRASS?  We would like to use our local image for
> teaching purposes and could not figure out how to have it done.
> We do have a 9 tract tape drive attached to an old PC ERDAS which is now
> out of order.   If possible, we also would like to connect this tape drive
> to the Linux so that we can read the files from tape directly.  At this
> moment, how to read an image file is the first priority.  Thanks again.
> Harry
> *  Don't take life too seriously!  You will never get out of it alive!   *
> * Harry K.C. Chang            Social Sciences Research Facilities Center *
> * harry at atlas.socsci.umn.edu  #25 Blegen Hall                            *
> * (612)625-3899               University of Minnesota,  MPLS, MN55455    *
> * 04-252-2678                 Associate Professor                        *
> *                             Land management Department                 *
> *                             Feng-Chia University, Taichung, Taiwan     *
