Chris, If you are sending an e-sized plot and only loading c sized paper you will lose or cut off some of your plot. The plotter when loading the media will look for the edges of the media when loading. It is always a good idea to put in a larger size than you send. This seems like a waste but it will give you the best results. Greg Thacker USACERL TAC
