Help with XKeysymDB file
    Ken Sibley
    ksibley at ncg.scs.ag.gov
    Mon Jan 31 16:58:36 EST 1994
> From grass-lists-owner at max.cecer.army.mil Mon Jan 31 15:48:44 1994
> Date: Mon, 31 Jan 94 13:57:38 EST
> From: ld+0075!dotson at uu5.psi.com (Doug Dotson)
> Sender: grass-lists-owner at max.cecer.army.mil
> Reply-To: grassu-list at max.cecer.army.mil
> Subject: Re: Help with XKeysymDB file
> Content-Length: 544
> I had a similar experiance when I downloaded the binaries.  I never did figure
> out why it happened and several from this list offered suggestion of which
> none worked.  For other reasons I downloaded the source and did a complete
> rebuild including XGRASS.  The problem went away.  This suggestes that the
> keysym table is compiled into the code.  I was not under the impression that
> this was the case, I thought the it was dynamically loaded at runtime.  I
> never persued it further since my purposes were satisfied.
> Doug Dotson
> dotson at tate.com
This is similar to our experiance.  The messages that I posted about two
weeks ago were for the binaries (of xdigit) that we downloaded from CERL.
We have since recompiled xdigit, with update 3 installed, and the XKeysymDB
warnings came back.  Using the strings command that I posted the note about
before showed two things:
%s/lib/XKeysymDB
/usr/openwin/lib/XKeysymDB
I then appended the motif XKeysymDB file to the /usr/openwin/lib/XKeysymDB
file and the warnings went away.  I did not have time to find where the
%s/lib/XKeysymDB message came from; more pressing things popped up.
Ken Sibley
USDA-SCS
