GRASS on Linux on SX
Charles E Meier
cemeier at magnus.acs.ohio-state.edu
Mon Jul 4 20:39:36 EDT 1994
In article <9407041100.aa16483 at pollux.GEOG.UCSB.EDU> you write:
>In a posting about Linux/Grass, Gerald Evenden wrote:
>>Suggest 16 Mb ram for starters, significantly better performance with 32Mb,
>>300Mb hard-disk (Unix usually runs about 200Mb) but a more reasonable size
>>is 600Mb. 33MHz 486 is starting cpu but, if you can, look at DX2's 50Mhz or
>>66MHz. NO SX's. Also be sure the motherboard has a good reputation, Unix is
>>not tolerant of some of the cheaper clones. Obviously, 1024x780x8 video
>>required and the bigger the screen, the better, but I get by on a 15 incher.
>Does this mean Linux and/or GRASS won't work on SX machines, or just run
>very slowly/poorly? I have a SX at home that I want to run GRASS and
>Linux on. Speed doesn't matter at this time (when it does, I'll get a
>new computer).
>chuck
I run grass under linux on a 386sx-25mhz w/ 9MB of ram, 16K cache, a slow
Trident video card, a poor 14" monitor w/ .52 dot res. (640x480x8), and
2 ide HDs (1=340MB, 2=100MB). I have a 387, but linux does have fp math
emulation code that can be configured into the kernel in the absence of a
coprocessor.
The whole thing actually didn't seem too gawd-awful horribly painfully slow
until I was given an account on some Sun or other running Arc-Info so that
I could finish off my PhD work. Now I cringe every time I bring up grass on
my home pc. But then I used to cringe every time I brought up Word Perfect
on my old XT after I bought the 386sx.
An 80486sx should be fine, but invest in at least 8MB or more of RAM.
* Charles E. Meier <Meier.1 at osu.edu> *
* - "You can learn a lot from listening to people talk. Why everything I *
* know today I've learned from listening to myself talk about things that *
* I knew absolutely nothing about." - Gracie Allen *
