Trouble w/ Solaris d.mon
    Jim Pirzyk
    pirzyk at cerl.cecer.army.mil
    Thu Jul 14 18:58:10 EDT 1994
In info.grass.user you write:
>Hello,
>I just successfully (well, almost) installed the compiled binaries for
>Solaris2.x from moon.  However, when I try
>d.mon start=x0
>I get the following error message:
>ld.so.1: x0: fatal: libX11.so.4: can't open file: errno=2
>Killed
>Error - Can't set up pipe to graphics device.
>Problem selecting x0. Will try once more
>I have located ld.so.1 on my machine in /usr/lib.  I cannot find libX11.so.4,
>the closest I find is libX11.so.4.3 in /usr/4lib.  I have tried setting the
>environment variable LD_LIBRARY_PATH to both /usr/lib and /usr/4lib and still
>get the error.  I have tried copying libX11.so.4.3 to libX11.so.4, but that
>did not work, as I expected.  I tried copying both ld.so.1 and libX11.so.4.3
>to LD_LIBRARY_PATH, but that does not work.
Try adding /usr/openwin/lib to LD_LIBRARY_PATH, that is where libX11.so.* are
usually stored.
- Jim Pirzyk
[Jim] pirzyk at uiuc.edu -------------------------------------------      __o
TAC & GrassNet System Administrator, US Army Corps of Engineers      _'\<,_
Construction Engineering Research Laboratories, Champaign IL USA    (*)/ (*)
