Intergraph Import/Export
Malcolm Williamson
malcolm at cast.uark.edu
Fri Jul 15 17:55:20 EDT 1994
> I know I have seen some discussion on this recently but could not find it
> in the archives. Has any one had success at exporting Grass Raster files
> to Integraph MGE (unix).
I haven't tried this, but I would expect it to be possible as long as
the GRASS raster file is uncompressed (r.compress -u) and you have all
of the header info from the cellhd directory. Note how many bytes per
cell are being used in the GRASS file (the "format:" in the header).
> Has anyone had any success at importing
> Microstation Design Files -- .dgn I think, into Grass. I believe the
> vector files started out as dlg3 optional, were imported and enhanced in
> Arc, and then moved over to the Intergraph MGE software. My problem is
> that I would like to use the files in Grass, with other data I already
> have and then give the whole data set back for use in the Intergraph MGE
> system.
Either a) have the files exported in DLG3 Optional format directly from
Intergraph, or b) import the dgn file to Arc/Info using the IDGNARC
command, and then export from A/I to GRASS. Sorry!
> Any help with this conundrum would be appreciated.
> Jim Klein
> lkla at netcom.com
> 703-739-0972
Good luck!
Malcolm D. Williamson - GIS Specialist E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies Telephone: (501) 575-6159
Ozark Rm. 12 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
