Still trouble w/ Solaris
Jim Pirzyk
pirzyk at cerl.cecer.army.mil
Sat Jul 16 16:27:28 EDT 1994
In info.grass.user you write:
>Hello,
>As Jim Pirzyk suggested to me,
>>Try adding /usr/openwin/lib to LD_LIBRARY_PATH, that is where libX11.so.* are
>>usually stored.
>I set LD_LIBRARY_PATH. Indeed, libX11.so.4 was located in /usr/openwin/lib.
>So I got past that problem. But I get another error.
>Graph_Set: can't open
>Error - Can't set up pipe to graphics device.
>Problem selecting x0. Will try once more
>I get that error for both x0 and x1. This is using d.mon on Solaris2.3 from
>the moon binary release. Any more words of wisdom?
What is the contents of $GISBASE/dev ???
- Jim Pirzyk
[Jim] pirzyk at uiuc.edu ------------------------------------------- __o
TAC & GrassNet System Administrator, US Army Corps of Engineers _'\<,_
Construction Engineering Research Laboratories, Champaign IL USA (*)/ (*)
